Se ha producido un error inesperado en el instalador al instalar este paquete. Es posible que se trate de un problema con este paquete. El código de error es 2381. The arguments are: E:, ,
=== El registro se ha detenido:
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [InstallMode] = HomeSite {string}
Property: [ProcessorArchitecture] = AMD64 {string}
Property: [VersionNT] = 6.2.0 {version}
Running checks for package ‘Microsoft Windows’, phase BuildList
Reading value ‘CurrentVersion’ of registry key ‘HKLM\Software\Microsoft\Windows NT\CurrentVersion’
Read string value ‘6.3’
Setting value ‘6.3 {string}’ for property ‘OsCurrentVersion’
Reading value ‘CurrentBuildNumber’ of registry key ‘HKLM\Software\Microsoft\Windows NT\CurrentVersion’
Read string value ‘17763’
Setting value ‘17763 {string}’ for property ‘OsCurrentBuildNumber’
The following properties have been set for package ‘Microsoft Windows’:
Property: [OsCurrentBuildNumber] = 17763 {string}
Property: [OsCurrentVersion] = 6.3 {string}
Running checks for command ‘SketchUpPrerequisites64\MinimumWindowsVersion’
Result of running operator ‘VersionGreaterThanOrEqualTo’ on property ‘VersionNT’ and value ‘6.1’: true
Result of checks for command ‘SketchUpPrerequisites64\MinimumWindowsVersion’ is ‘Bypass’
Running checks for command ‘SketchUpPrerequisites64\64BitArchitecture’
Result of running operator ‘ValueEqualTo’ on property ‘ProcessorArchitecture’ and value ‘AMD64’: true
Result of checks for command ‘SketchUpPrerequisites64\64BitArchitecture’ is ‘Bypass’
‘Microsoft Windows’ RunCheck result: No Install Needed
Running checks for package ‘Universal CRT (Hotfix KB2999226)’, phase BuildList
Looking up path for special folder ‘SystemFolder’
Running check with folder ‘C:\Windows\System32.’ and file ‘ucrtbase.dll’
Attempting to find file ‘C:\Windows\System32.\ucrtbase.dll’
File version is ‘6.2.17763.404’
Setting value ‘6.2.17763.404 {version}’ for property ‘UCRT’
The following properties have been set for package ‘Universal CRT (Hotfix KB2999226)’:
Property: [UCRT] = 6.2.17763.404 {version}
Running checks for command ‘SketchUpPrerequisites\InstallPrerequisites.exe’
Result of running operator ‘VersionGreaterThanOrEqualTo’ on property ‘UCRT’ and value ‘0.1’: true
Result of checks for command ‘SketchUpPrerequisites\InstallPrerequisites.exe’ is ‘Bypass’
‘Universal CRT (Hotfix KB2999226)’ RunCheck result: No Install Needed
Running checks for package ‘Bibliotecas de tiempo de ejecución Visual C++ “14” (x64)’, phase BuildList
Running MsiProductCheck with ProductCode ‘{F106B700-BFF8-3065-B305-14D36AD40539}’
MsiQueryProductState returned ‘5’
Setting value ‘5 {int}’ for property ‘VCRedistInstalled’
The following properties have been set for package ‘Bibliotecas de tiempo de ejecución Visual C++ “14” (x64)’:
Property: [VCRedistInstalled] = 5 {int}
Running checks for command ‘vcredist_x64\vcredist_x64.exe’
Result of running operator ‘ValueGreaterThanEqualTo’ on property ‘VCRedistInstalled’ and value ‘3’: true
Result of checks for command ‘vcredist_x64\vcredist_x64.exe’ is ‘Bypass’
‘Bibliotecas de tiempo de ejecución Visual C++ “14” (x64)’ RunCheck result: No Install Needed
Running checks for package ‘Microsoft .NET Framework 4.5.2 (x86 y x64)’, phase BuildList
Reading value ‘Release’ of registry key ‘HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Full’
Read integer value 461814
Setting value ‘461814 {int}’ for property ‘DotNet45Full_Release’
Reading value ‘v4’ of registry key ‘HKLM\SOFTWARE\Microsoft\NET Framework Setup\OS Integration’
Read integer value 1
Setting value ‘1 {int}’ for property ‘DotNet45Full_OSIntegrated’
The following properties have been set for package ‘Microsoft .NET Framework 4.5.2 (x86 y x64)’:
Property: [DotNet45Full_OSIntegrated] = 1 {int}
Property: [DotNet45Full_Release] = 461814 {int}
Running checks for command ‘DotNetFX452\NDP452-KB2901907-x86-x64-AllOS-ENU.exe’
Result of running operator ‘ValueEqualTo’ on property ‘InstallMode’ and value ‘HomeSite’: true
Result of checks for command ‘DotNetFX452\NDP452-KB2901907-x86-x64-AllOS-ENU.exe’ is ‘Bypass’
Running checks for command ‘DotNetFX452\NDP452-KB2901954-Web.exe’
Result of running operator ‘ValueNotEqualTo’ on property ‘InstallMode’ and value ‘HomeSite’: false
Result of running operator ‘ValueGreaterThanEqualTo’ on property ‘DotNet45Full_Release’ and value ‘379893’: true
Result of checks for command ‘DotNetFX452\NDP452-KB2901954-Web.exe’ is ‘Bypass’
‘Microsoft .NET Framework 4.5.2 (x86 y x64)’ RunCheck result: No Install Needed
Launching Application.
Running command ‘C:\Windows\SysWOW64\msiexec.exe’ with arguments ’ -I “C:\Users\ASUS\AppData\Local\Temp\7zS2465.tmp\SketchUpPro2019-x64.msi” ’
