Changing the default dimensions text font
Hello,
It seems (while using Sketchup Free for WEB) that the default font text used for Dimensions is not the best choice and I have to manually change each dimension that I’ve added.
How/where do I go to change the default text font and size so that I don’t have to edit them all the time one by one? It’s really annoying and time-wasting after a while…
Thank you in advance for any help you can provide!
You can set the size of all existing dimensions en masse by selecting them all and then changing the size in Entity Info. Once you’ve set the font size for the model it should “stick”. The font size is a model setting. You could open a blank model file and set the font size as you want and then save that empty file to your Trimble Connect storage to use as a template. In the future when you want to start a new model, open that blank file and create the model in it. Remember to use Save as … and give the file a new name so you don’t overwrite the blank file.
