Changing multiple groups into components
Hi guys
Looking for a bit of advice.
I’ve been designing some small pods in timber. I have been doing it brute force method for a while. Using components and Open Cut List for reporting. It worked very well for a bit. Now the work load has increased and I need to be more efficient in my design work. I started running medeek Bim plugin and has really helped a ton.
The one thing I miss is the easy setup and great reports I could generate from OCL.
The issue I am having is medeek creates groups instead of components so OCL doesn’t pick up studs and top plates and such…
My question is, is there some sort of script or plugin that would automatically change each group into a component?
I use this one all the time…
https://extensions.sketchup.com/extension/4f10947f-6ce8-4295-a372-eae6e7cd3cae/groups-to-components
It’s made by @thomthom
Thanks. This worked pretty well. Did exactly what it says it does. The issue with this is it doesn’t dig deep to change all groups to componets. The other issue is once I do this it breaks it from the medeek plugin so you can’t use it to modify anything using the plugin.
With that said, I can keep 2 copies work on one and pull reporting from the componentized model. Bit of a pain but @medeek is saving me alot of time modelling.
I haven’t used the Medeek plugin, but I use thomthom’s selection toys - it also has the function it converting groups into components. Bonus that when you are selecting them you can choose active, by layer, etc. It goes deep, into nested groups and components as well as hidden, tags that are off, etc. when you make the selection - then you can convert what you’ve selected into components.
But if the same group is mirrored, or if a dynamic component is mirrored, it doesn’t add it to the selection… something going on in the background that changes how they are recognized.
Thanks
Going to have a look.
S4U components in my opinion is the best tool for this kind of work, it’s a paid one though.
Thanks I’ll have a look.
Only a year late to this thread…
I have a model from an architect (must’ve converted to a sketchup file from another software) and all of the entities are groups not components. Trying to use this extension to convert them to components (End goal is to generate a report on all of the timbers to get a quick and easy take-off for early budget pricing).
I downloaded the extension but cant see how to use it… Usually all my extensions are in the “extension” drop down…
You need to install its Requirements too:
TT_Lib²
Restart SketchUp after installing, then you will have a menu item in Extensions>>‘Convert Groups to Components’
Thanks. I just installed that as well.
I still don’t have the menu item in my dropdown for some reason.
Now when I try to open “Extension Manager” nothing opens. I did just leave my home desk and am working of my laptop now so I figured the window was just opening “off-screen”. That does not seem to be the case either though… Tried restart sketchup, my entire machine, nothing… hmmmm
https://forums.sketchup.com/t/extension-manager-warehouse-wont-open/278207/2?u=dezmo
Thanks, I actually tried this already and it doesn’t seem to work…
Although it does see like that would be the issue…
It only moves around my sketchup window. which makes me think the manager is not opening at all…
That means you are doing something differently…
Close your SketchUp, then reopen SketchUp, then :
  • Follow the guide exactly as written.
Yup. It worked differenly when I reopened sketchup. Must have been doing something stupid… whoops.
Thanks for the help here @dezmo !
