Is it possible to change the size of the tick mark in LayOut’s dimensioning tools?
Ii would like to have a broader tick mark but keep the dimension line thin.
When one adjusts the line weight, the tick mark does get wider, but everything gets wider, broader. I am guessing that the tick, like the dot and the arrow heads, is a “block” defined somewhere with in LayOut. Can I edit this block?
You can change the width of the tick mark a little with the size of the start and end arrow but the dimension line gets longer past the extension, too. Maybe you can find a balance that works.
