Hi,
It should be possible to change “Sketchup Model” settings at once for multiple viewports.
Often you have a template and you want to change the tags in multiple viewports.
It kind of works with scenes, but this means you loose your scene selection and I use them for my sections. I prefer that per parameter the settings of the change and all th eother setting stay the same, so if you switch a tag on or off, the scale, the other tags and ortho, etc… stays the same.
