I’m brand new to SketchUp and has just started my first project, drawing an extension to my house.
After doing several hours of work I realize that I have made a mistake. The width is only four meters instead of four and a half.
I have added windows and god knows what to the drawing and now wounder if there is an easy way of changing the complete plans to 4.5 meters wide instead of the four it is now?
I understand I can change every single element one by one but that is a crazy amount of work. Almost better to start fresh then…
I browsed the forum and found out that you can use the tape measure and “alt” and then just type in the new measurement.
Worked fine but some fill stuff got mixed up and some inserted items disappeared.
I’m happy though - minor updates and the drawing is now the correct size.
Hoping to use this to get a building permit for an extension.
As long as you got what you need out of it, that’s fine. You might be able to change the way you did the resizing so that you only changed the dimensions that needed it. But as I said before, without the model to look at, it’s hard to tell you exactly how to do it.
Since you didn’t really use an components and the walls have no thickness, it was pretty quick to fix. I switched the camera to Parallel Project mode and aligned the camera so I was looking straight on at the large window. A left to right selection box around the right side selected the side wall. the right side of the large window, the railing, and the yellow siding areas which I just Moved over to the right 500mm. then I selected the bottom window, again, with a left to right selection box and moved it to the right to center it on the wall. I used inferencing to align the center of the window with the center of the wall. I also did that for the center area between the two large windows.
Do take note of DaveR’s comment and make proper use of components, or your drawing will quickly become unmanageable.
Use the Help, and follow a few basic tutorials. There are several posts in this forum with links, but I can’t access them easily from my phone at the moment.
In my defense I must say that I downloaded SketchUp Sunday PM and fiddled around for a few hours that afternoon. That is all I ever done in SketchUp or any similar program. So I am an absolute beginner.
Also, I need a drawing to get a building permit for my extension, so no need for thickness of walls etc. I just wanted to keep things as simple as possible.
Huge thank you for helping me out Dave!
