Working on a drawing set and getting odd behavior I don’t understand in SKU & LO 2024.
The images below show that I have a cabinet door swing on a tag with a dashed line. But I can not get it to be dashed. I had the new graphics engine on and since it is haphazardly degenerating the results I have started shutting it off.
In this case, I turned it off but the lines that are supposed to be dashed still aren’t. It transfer into Layout as well. Dashes don’t populate as dashes. Style changes don’t seem to make a difference either. The last image shows some swings present, others not. Some even appear to have the dashed lines but they are dashed and then solid.
I also see that some times lines are broken or just plain disappear. Im working in a new template for architecture now. Have a very solid template for cabinet CD’s and I don’t get this same result in 2024. Everything transitioned really well. Now im in this new template and Im just not getting the same experience on the large paper size and different template.
Let me know if I need to share the LO file.
