even though I deselected ‘pattern’ in the shape style…I still get grey per encl…I tried to import a custom ‘white’,
but it still went grey on me…Ugh…anybody?..
thanks,
chris
thanks,
chris
Is it possible that the gray background behind the elevation view came in to layout with the SketchUp model? When you are in SketchUp, you need to set the background, sky and ground color to white through the “styles” menu and then when you insert the model into Layout and open the saved scene, the background will be white on the layout sheet.
Thanks for the tip…I did go back and do that in skup…I set to all white in the in the ‘hidden line’ style…looks good in skup, then still comes thru grey…■■■■…
