What Peter said. Or drag a right to left selection window around the outboard ends of the faces you want to get rid of and hit Delete.
AwW! I didnât say that correctly-- You must hold down the shift key when you double-click to de-select. (I forget what my fingers are doing, it becomes second nature.)
Iâm still trying to figure out how to create a cylinder with rounded ends. Is that possible in Sketchup Free on the web?
Yes. Itâs possible. Draw a cross section of the cylinder and a circle for a path. Use Follow Me to extrude.
Be sure to draw the round-ended cylinder object at a large enough scale (and with small enough counts of segments in the arc ends and the circle path) to avoid SketchUpâs limitations of very short edge lengths. Otherwise there will be mysterious holes at the âpolesâ of the hemispherical end caps.
