Cannot view all Material Palette icons
For some reason the two outermost buttons in my materials pallet are barely visible and text is cutoff. . If I use my pencil and carefully place it on the edge I can see I can sometimes access those. It’s also a problem with the pallet itself but in that area I can pinch zoom in and out so at some point i Zoom in or out enough the items per Row will change and previously hidden can be seen. I checked to make sure the iPad Text zoom or magnifier is not turned on or any other accessibility feature and removed the app and reinstalled but still having the same problem.
It’s only happening in the dialogue box for materials - all others are displaying correctly.
Has anyone else experienced this and if so did you get it figured out or figure out a work around?
I’m really at a loss here. Without the ability to see and select those other button in the materials palette it sort of make it impossible to do much of anything. One of the buttons connects to the warehouse to bring in materials and the other I believe is for new materials. When I try to report a bug it says my license doesn’t support tech support and I need to contact my account admin - which makes no sense because I’m paying for the software access every month independently, not through work or anything.
i opted to not get a personal laptop and instead go with an iPad this last time after my old laptop was no longer supported, thinking this would suffice but starting to think that was wishful thinking.
@Danimaupin may have ideas about this.
If you drag the icon into a new position in the sidebar, does the problem stay with materials, or does it transfer to the box that takes its place?
Problem stays no matter where it’s located. I can resize the thumbnails by using the pinch and squeeze/separate finger motion but only in the palette itself not the overall frame and its buttons. I keep thinking maybe there’s a iPad os setting that is set to zoom or something because for a while there I kept refusing to accept that my eye sight is starting to weaken as I get older and I know I played around with those settings on my phone (although don’t recall ever doing so on my iPad) while I was still trying to wear contacts. I wear Glassers primarily now so thought I rest everything so I didn’t need readers but this problem still there. The weird part though is how it only affects this and not the other sidebar options. But again to answer your question no it doesn’t matter if the palettes is docked to the side or floating anywhere it still is making those buttons in the side barely visible.
