I create a rectangle the pull it up and make it a Group. I want to Split it but cannot seem to make it work. Is it a resolution issue? The object is checked as Solid with the Solid inspector. Any help would be very welcome. !
What method are you using to try to split it? Often this kind of question comes from not opening a group for edit before trying to modify contents.
Hi. I am trying to utilise the Split tool which appears in one of the menus of SU Go.
What are you using to “split” the block with? The tool is meant to be used on two intersecting solids.
Thank you so much! I was completely under the wrong impression on how it works! I’ll experiment more tomorrow, but this video was a great help, Thanks again
