I’m pretty sure that the problem here is me and not Sketchup, but I’m not sure what I’m missing.
I am finding getting dimensions in SketchUp extremely frustrating. Even using the following simple example:
Create new drawing using Architectural mm template in Make 17
Draw a square 2000 x 2000
Pull the square by 2000 to create a cube
At this point I select the Dimension tool and try to select a corner or an edge. The cursor reverts to the previous tool, but doesn’t behave like previously. Edge or point no selected. Try for a while. No dice.
Select all face and group. Try again. No Dice
Convert the object to a component. Try again. No dice.
Very occasionally I will select an edge and get a dimension to pull out. Initially I thought the issue was my model. But repeating the steps above has the same end result.
Could you share an SKP file in which this fails? I’ll try it on my Mac and see what I get. Do you have problems selecting an edge with the Select tool?
Generally issues with selections and clicking on endpoints or edges is related to the graphics drivers. Intel graphics seem to be very problematic, too.
you should be able to dimension ungrouped geometry or grouped. You can’t dimension an edge if it’s in a group that is closed, though. You would need to open the group to select the edge for dimensioning.
Looks like I’ll be doing that tomorrow. At least we seem to identify I’m not doing anything wrong per se.
Will feedback after reinstalling in the morning.
OK. Have deleted and reinstalled SketchUp Make and still having exactly the same problem. Unless anyone else has a suggestion I’m going to assume that it’s either my MacBook Air, or some combination of software that I’m working on.
The ‘need’ for dimensions this time around has passed - I only discovered them right at the end of the current project at home, and we’ve managed without them.
