Cannot add Location to model “model is already georeferenced”
I’ve created a model of a house. I went to add location to be able to model location specific lighting conditions and as I enter in location to add, it gives me a prompt “this model is already georeferenced at a location more than 1000m from the location you’ve chosen. This may result in poor alignment. Continue?”
I have tried to continue, but nothing happens or it’s taking an extraordinary time. My model disappears and when I zoom to extents there is nothing there.
I have created new models with nothing in them and can apply the location with no dramas. I thought perhaps the materials I imported may have locations, so I removed all materials, purged, saved and tried to apply the location but I still get the same prompt and result.
How can I fix it to apply my own location? Not to the location the model appears to be defaulting to?
Is there a way to change the location even though I can’t see where it’s geolocated to?
I don’t want to recreate the model from scratch but I do need the correct sunlight, is there a workaround?
Note that I’m using Sketchup for iPad
Do you have components from the 3d warehouse in your house model? Some of these may be geolocated (I’ve never understood the need to geolocate a couch or a stove, but ¯_(ツ)_/¯ - this might be affecting your model.
When the model is geo located at the wrong location, you can open the “model info”, go to “geo-location” and use the “clear location” option to remove the attached location. Once deleted, you can add a new geo-location to your model.
Go to Window - Model Info - Geo-location and click on Clear Location
@colin - Delete from inside Add Location has a problem.
Thanks for your advice. This seems straightforward enough, however, I do not have these items in the model info menu of the iPad app. I don’t suppose you know where I can find this in the iPad app version?
Oops, my apologies, didn’t notice you’re using the ipad version.
Hope another ipad user can show you where to find this option :crossed_fingers:
Thanks for the input but I do not have the same menu options, etc. in the iPad version. The only location item from what I can see is in the shadows menu. Do you happen to know how to clear location in the app version?
Thinking this may have been the issue, I removed all items from the warehouse but still doesn’t appear to have cleared the location to resolve.
I have now tested in SketchUp for Web (Go) and the Delete button works as it should.
Hamburger menu > Add Location > Delete.
An iPad user can tell you more precisely. @Danimaupin
There is no obvious way to delete geolocation in the ipad version. You can add a location but not delete.
And as mentioned, when you add a new location it tells you it already is geolocated but gives you no option to delete the first one, just a warning that the alignment may be incorrect, and sure enough it drops the new terrain at a distance from the original, making it worthless.
This did it. Thank you. This saved me hours of remodeling!
