Can Sketchup do tile like this?
can I use floor generator to get to this?
any other plugin?
thanks
The easy method of doing this would be using an Image Texture… plus a bump map and displacement map while using a render… (like VRAY) … you can find free materials with bump and displacement maps online for free also.
Yes, a texture is the most probable way to go.
For less difficult patterns, there is the Mosa Pattern Generator:
It will produce accurate textures for SketchUp and other software. And give you quantities, as well!
