Is it possible to model and air source heat pump system (ASHP) with Sefaira? I do not see ASHP listed as an option anywhere in the program. I’m also not an engineer or HVAC specialist, so it’s possible I’ve just missed something.
I might just be the dummy that answers his own question. This article appears to provide an answer: https://support.sefaira.com/hc/en-us/articles/115000249971-Air-to-Water-Heat-Pumps-Explained
Just in the interest of confirmation, here is what I’ve done:
selected “fan coil unit and central plant” as the overall system
in the water-side tab, select “heat pumps” and “air-cooled chiller”
Is that correct?
Hi Chaidan3
Heat pump systems name needs to include the type of medium that is used as a source of heating or cooling energy and the medium that is used to deliver the heating or cooling energy. First medium in the name is always a source. So knowing that we can have the following combinations:
- Air to Air Heat Pump
- Air to Water Heat Pump
- Water to Air Heat pump
- Water to Water Heat pump
What you are describing is most likely the option # 1 but in any case I will list which systems you can use for each type of heat pump:
- PTHP/Split system
-VRV Fan coils (Heat rejection is Air-cooled)
- Any system that requires a boiler where as a boiler you put “Heat Pumps”
- VRV Fan coils (Heat rejection is Water-cooled)
- Water Source Heat Pump Fan Coil
- Not supported directly
Thank you so much for the answer!
