Camera tool
I use camera tool to make a scene and send to layout.
All is well until i try to export it as PDF when it show the doc.
to be saved everything has what looks like background lines all
through it. Could someone please let me know what i am doing
wrong.
Thank you
Share your LO file so we can see what you are working with.
Are you still using SketchUp 2021 as indicated by your forum profile?
My random guess is that your model is a largish distance away from the SketchUp origin point and your LayOut viewport is set to Hybrid rendering or (if you are using v.2023 or 2024) Output Override is enabled. Easiest is to stick to Raster rendering and set the export resolution to High.
Hi Dave
I have know idea how to share files i’m old old school .
Thanks for your reply
If it’s less than 16 Mb drag and drop the file into a reply here. Otherwise upload it to DropBox or Google Drive and share the link in a reply.
HI Anssi
I did as you said and it work Thank You .
If that worked, you really should fix the way your model is set up in SketchUp.
Thanks Dave
I did what Anssi sent me and it worked.
I will use the info you sent me no the file next time.
Yes. I saw that you told him that. I told you that you really should fix your SketchUp model.
