Camera Standard Views
But is there any menu or keyboard shorcut that allows me to use bottom view without adding any new extension?
I believe you all when it says it’s pretty unnecesary, but I think it’s neccesary, it’s probably because I still don’t know how to use this program well.
You don’t need an extension of a keyboard shortcut for the bottom view. Go to Camera>Standard Views>Bottom. You can set a keyboard shortcut for that if you need to. For the few times I need a bottom view, it’s just easier to orbit to look from below.
Ohhh, thank you so much, @DaveR.
I thought in standard view menu I would find the same views there are in the view toolbar.
As I wrote in another post I’m drawing a simple object, a pencil, and I would like to add the typical rubber so … I think I would work better from the bottom side, I guess I could also rotate the object or just use an isometric view
You should be orbiting the camera with the center mouse button. You would find that much easier and more efficient.
I guess you mean like this (I want to outline the hexagon to use it to modelate a new component)::
Yes, that’s orbiting the camera, not rotating the pencil. And you can easily zoom in on the end to do what you want with it.
