Bumping the Feature Request for Dual Dimensions in Layout
Well, all of the previous threads asking for dual dimensions in Layout are closed so I’m starting a fresh one. It is really a slow and cumbersome process dimensioning a Layout document in Imperial and Metric. This should be an easy and simple operation but instead takes a very long time and is full of potential errors. It’s such a common thing for many of us and for other programs and it’s not going away, can we please have a method for choosing stacked dual dimensions in Layout?
It’s the little things that make a professional tool really work for professionals. Thank You.
2023
2017
2018
I agree that dual dimensioning would be useful.
Have you seen my relatively quick workaround?
I don’t believe I have. Would like to see it if you can share. Thanks.
I’ll share it with you when I get home.
I do it manually and its a pain.
I haven’t had a huge need, but I agree. I can imagine it’s more important in Canada.
The method I’ve used in PowerCADD, seems doable in LayOut by copying all, pasting in place and changing them to metric and below instead of above, maybe even on their own layer. How that plays out managing them as things change I don’t know other than to delete them all and do the drill all over again?
That does work in LayOut. You wouldn’t have to delete and redo the dimensions, though. You can have both sets of dimensions connected to the model. When I need to do this I have each set of dimensions on a different layer which makes it easier to access one set without having the other set in the way.
dual
Still, it would be nice to have the dual dimensions as a setting in LayOut.
When I copy and paste dimensions, they lose their connection and even their scale. How do you get both sets connected to the model?
Usually they connect automatically for me. Once in a while I have to reconnect them by moving their anchor points. That’s usually not an issue for me. In most cases I haven’t needed to add the second set of dimensions until after I’ve pretty much got the model carved in stone. Then the client comes back to me with something like, “Oh, by the way, we need the dimensions in metric as well.” Then I don’t bother connecting them and just set the dimension scale to match the viewport.
As I wrote, I would welcome automatic dual dimensions in LayOut but I don’t find the workaround such an onerous task. If our European friends get their way there won’t be a need for dual dimensioning anyway. :wink:
I am investigating a plugin for dual dimensions in Layout.
The approach is:
  • Take a Layout document with single-unit dimensions
  • Select a target unit system (unit type, unit precision, unit measure for decimal)
  • Generate a copy of the Layout document with dual dimensions
This allows to keep the working Layout document untouched and just get a copy of the document at the end. The main reason is that as soon as you touch dimensions in Layout (like adding custom text), you may disconnect the dimensions from the underlying model.
The plugin would also work for just replacing dimensions in one unit system into another unit system, so that you get for instance the original document in decimal units and a copy in imperial units.
I made a few tests to check the feasibility. For instance, if you start from the original document:
You obtain the generated document as:
I anyone is interested, just contact me. This is a fairly easy plugin, so it should not take long to develop and publish.
For info, the plugin is published at Sketchucation as LayOps.
Here is a video to give an overview
When this topic comes up I think if it is ever addresses in future versions it would be great to combine any combination of dimension types. Beyond inch/mm , engineering / arch would have its use and I can think of others where you spare the document viewer the pain of grabbing a calculator.
