We have multiple versions of a file that all need to be cleaned up. Is there a way to batch purge multiple files? If there is a way to script this, I have a list of file names & paths on which to execute the purge command. Thanks in advance!
@TIG has an old script here …
https://sketchucation.com/pluginstore?pln=TIG-batchpurge
It is not an extension, you’d need to run it from the console.
It also likely predates the exposure to the API of the select directory method, so it uses the directory path of the active model. It could likely be polished up allowing the selection of whatever directory you need, rather than that of an open model.
