Building with Nudura ICF 6" and 8" form units (Standard, Corners, & one sided taper top). Anyone have models available
Need someone that can model Nudura ICF as accurately as possible for my build
You might find it useful to get their .dwf files and import them yourself using the SimLab DWF importer which you can get through the Extension Warehouse.
I find that it isnt necessary to have a model with finite detail. You will probably submit a drawing to the ICF company for review and quote. Nadura uses HercuWall for wall Panels. I have designed for HercuWall Applications and All they needed was the plan view. You draw the wall as a solid at the correct thickness. They engineer the headers and other openings. If your doing wall panels the HercuWall website has Details that are great for your working drawing set.
I have created generic details using ICF blocks from the 3D warehouse but I wouldnt create a model with all those components the file would be huge!
Keith,
Here is a SketchUp model of a Nudura 12" form. Is this what you are looking for?
Would you like SketchUp components for for the 6" and 8" forms (Standard, Corners & one side taper top)?
250709A_Nudura_Blocks.skp (1.1 MB)
SimLab for some reason isn’t supported on MAC OS. I wish I could all cause all the BIMs and files I need are in Nudura’s Library. Ive got 6” and 8” but I need 10” Standard and 10” one sided taper top, and corners
Hello Ernest, If you could, I would be interested in getting all the 8” forms.
Many thanks
Mike
