Hi guys, does anyone have any recommendations for building and designing the inside of a home with multiple rooms? E.g is it best to build the walls first then the outside ? Or build push pull boxes then put doors between them?
To b e honest I would start with a rough floor plan on a piece of paper. Then I would put it in SU and refine the floor plan before adding walls etc.
If you use layers for your Groups/Components, it does not really matter what you draw first.
Watch tutorials on youtube and see which style works best for you.
@mihai.s makes the key point: use groups or components to prevent things from sticking to each other without your explicit intent that they should do so.
Here’s a basic house modeling primer…
