Bugsplat Crash Report
Hi there i am having a problem with my sketchup file.
I already sent the crash report but i want to learn the main reason behind it.
Maybe a script or a plugin that i am using making this.
Crash #900863
Any help will be great.
Thanks.
If you were a bit more descriptive about what is happening, perhaps shared the problematic file, explain why (if) you are using the 2025 version, and have you tried it with the 2026 version yet… what extensions do you use…etc— you might stand a better chance of getting better explanations…
Recently, while working on a master plan model, SketchUp has started crashing frequently—sometimes while drawing a face, placing a point, or using the Push/Pull tool.
The model contains a large number of imported DWG files, and many plugins are installed. However, the crashes occur even during basic operations such as drawing a few lines or using Push/Pull.
I will try with 2026 but obviously this problem occurs at my colleagues pc but not mine which is 2025 version also. We are working on almost similiar model files.
Can you post the .dmp file and the bugsplat file?
