Brail 2 font for SketchUp to provide accessibility media
I am looking for a font to design Accessibility Media in Brail 2 font. is anyone aware of a source for brail 2 in SketchUp and how this should be installed.
I saw this on the web but wanted some background before jumping in, if someone has experience with this and can provide guidance it would be greatly appreciated!
Euro 850 font
3.2 Braille in Sketchup - tactiles.eu
A way to do it, without extensions, would be to use the Braille font to make a flat and un-extruded 3dtext object and create a component of the hemispherical bump the right size.
Use a circle path and 1/4 circle face and followme…
Move its origin to the bottom center.
Place the bump components onto the 3dfont pattern, snapping to the dots center, and then delete the original 3dtext part.
Group or make a component of the bumps, giving it its name in text.
You can reuse the bump component in any new situation.
If you want another size then use make-unique on a new instance and scale it as desired…
Another option might be to extrude the dots a bit and then use the Round Corner or FredoCorner extension to round the dots. I’m working with the model units set to Meters to avoid issues with tiny faces.
BUMPS
Do you need the actual geometry for the braille? When I was searching for a Braille font I came across one with shadows. If this is just for signage in images of your model maybe you could use that font to create images to insert. That would reduce the geometry count and perhaps make your model easier to manage.
Use will be presentation and documentation for fabrication.
On a relatively small sign, the copy and brail (and ISA) will define the sign size per CBC 11B 703
11B-703.3 Braille
Braille shall be contracted Grade 2 and shall comply with Sections 11B*-703.3 and 11B*-703.4.
11B-703.3.1 Dimensions and Capitalization
Braille dots shall have a domed or rounded shape and shall comply with 11B*-703.3.1. The indication of an uppercase letter or letters shall only be used before the first word of sentences, proper nouns and names, individual letters of the alphabet, initials and acronyms.
11B-703.3.1
BRAILLE
MEASUREMENT RANGE MINIMUM IN INCHES MAXIMUM IN INCHES
Dot base diameter 0.059 (1.5 mm) to 0.063 (1.6 mm)
Distance between two dots in the same cell1 0.100 (2.5 mm)
Distance between corresponding dots in adjacent cells1 0.300 (7.6 mm)
Dot height 0.025 (0.6 mm) to 0.037 (0.9 mm)
Distance between corresponding dots from one cell directly below1 0.395 (10 mm) to 0.400 (10.2 mm)
  1. Measured center to center.
    FIGURE 11B-703.3.1
BRAILLE MEASUREMENT
11B-703.3.2 Position
Braille shall be positioned below the corresponding text in a horizontal format, flush left or centered. If text is multilined, Braille shall be placed below the entire text. Braille shall be separated 3/8 inch (9.5 mm) minimum and 1/2 inch (12.7 mm) maximum from any other tactile characters and 3/8 inch (9.5 mm) minimum from raised borders and decorative elements.
BLA BLA BLA Location …
the long way to say no faking it.
OK. So if you need to model the actual geometry for the sign in SketchUp, I would suggest you use the “Dave Method” to avoid the tiny face issue. Or model the sign in meters (so a dot would be modeled at 1.5 to 1.6 meters in diameter and then scale them down afterward.
