How can I run a border around a group of objects, similar to the outline command? I drew a bunch of hearts and want to run a line .060" away from the outside, conforming to the outer-most shapes.
Thanks for any info…
-Mike
hearts2.skp (1.7 MB)
Something like this?
You can use Offset on selected edges. There’ll be some gaps you need to fill in manually but since a lot of the geometry is repeating, you can create some of the curves and copy them to make an array.
When you get finished it should look something like this.
Please fill out your profile with SketchUp version, operating system, and graphics card. That information helps us help you.
