Need help separating objects
advice
#1
Hello, I’m new to SketchUp, I am currently using it for free. I’m drawing a simple object and I need help for this problem:
I make two lines inside of an another object in order to make a thing like a barrier, when I pull it up it goes like this:
But instead I want it to become a separated object, so it won’t interact with the other face. It should be like a barrier inside that object. How can I do that?
#2
Draw one side at a time and make it a component or group before you draw the other side.
What exactly is this thing supposed to be?
#3
Press Ctrl when you pull it up. And later, don’t forget to erase the bottom lines.
