I am trying to create a boat with a similar sloping hull to the picture. I have tried to boleon cut spheres and other shapes from the boat itself, with little effect. Any suggestions please?
thanks
Keith
You don’t appear to need to cut spheres. Draw the plan view in 2D, and use solid tools to subtract an angled volume on each side to create the bow.
Sorry
I think that’s what I have failed at so far. The problem is that the cut is almost curved /sphere like
Build the ribs of the Hull first then use soap skin and bubble plugin to fill in the gaps
excellent thank you!
really helps!
Worked a treat
simple creating the shape in half the section, running the subtraction and mirroring was brill:)
I learn something new every day!
boat hull demo.skp (126.1 KB)
This is the skp you are looking at.
Ok I see what I did wrong! I didn’t rotate the subtract block in two angles!
Really thanks again! Much appreciate your time and effort to help!
haha…I only got the reference on the second look ![]()
thanks
You’re welcome - it only takes a couple of minutes.
