Blue line around component
I’m having some issues with the CutList attachment. It’s reading these objects are rectangles even though they are triangles. I’ve tried moving the axis but can’t seem to get it working properly.
The cut list extensions can only report the size of the blue bounding box, not the shape within. And component/group bounding boxes are always rectanglular prisms.
FWIW, everything is working properly.
The blue box is simply the bounding box of the group or component- and it’s always going to be a rectangle.
FWIW, if the grain of the wood should run parallel to the hypotenuse of the triangle, you should probably change the axes so the boudning box aligns with that side.
