How do it get rid of this. its very annoying. It just popped up one day.
That isn’t something SU specific.
Did you download something with a water mark?
What happens if you untick the layer SMEC_SQURKLE_TEMP? or is that yours.
Check the Style setting/Watermark and remove it if it is there.
That layer is from my DWG that I imported.
The water mark style settig doesnt change anything.
It popped up when i downloaded sketch up make and then we got a new license for pro 2018 and it just stayed. i cant select it or do anything with it.
Upload a model that shows it.
Looks to me like a head up display from some other program. Might pe an extension but could also be some whole other application.
I think it’s an Alienware laptop thing. I use Mac but read this, it might be caused by Nahimic 2 sound software and the sound tracking feature. Try CTRL + SHIFT + C or CTRL + SHIFT + S to disable it.
Or, go to the Alienware Sound center, go to Audio Recon and turn it off. That may also solve the issue.
Note to self: Don’t get an Alienware computer, or at least make sure to cleanse it of their crapware if getting one.
I’m sick of developers that make such features -_- . There are tons of programs that use Ctrl+Shift+S for things like saving all open documents, save as or similar commands. These key combinations belong to the active program, and should never be hijacked by a background program.
Thank you so much!! the problem is solved!
Thank you!
This solved the problem!.
