I really want to use Sketchup and Layout for everything but something holding me back is a poor set of dimensioning tools. I would love to have a dimension tool similar to Autocads “Baseline Dimension” where you can click a point of origin and do a string of dimensions from that point. I do a lot of layout drawings where dimensions are pulled from a grid. Im tired of exporting my model to DWG for annotation and dimensioning. Please add this feature!!!
Also I want more freedom to suppress the starting or ending line. We should have freedom to adjust the parameters of the dimensions so they are just how we need them to be. If you could replicate the control of autocad on your dimension and annotation tools then Layout releases its true value and potential.
You can kind of do this with layout by using the double click feature.
Check out this handy link for some great layout dimension tips.
Please add baseline dimensions to Layout, such as the image below. We currently have to use white boxes to mask portions of the dimension lines to achieve this effect and it is VERY time-consuming. Also, b_clam’s comments about suppressing start/end lines is spot on! We need this feature!
I have a lot of problem in picking the points of the dimension when i have, for example, rounded corners.
Is there any tricks to do that easly? Filter for inference?
Thanks Dave,
I appreciate your in here, but I’m an architect with particular tastes as to what I want my dimensioning to look like. Frankly, and no offense, but what you are showing below is no acceptable to me. Why can’t I just make the text box completely transparent (and smaller) then the problem is fixed.
Kendall Springer | Architect
u ** cornerstone** design group
5266 Blue Spruce Circle
Holladay, Utah 84117
Phone: 801.330.0679
Please note: This message may contain drawings, specifications, and other documents prepared by Cornerstone Design Group or its consultants that are considered instruments of service and are to be used solely with respect to the intended project. Cornerstone Design Group and its consultants are deemed the authors and owners of their respective instruments of service and retain all common law, statutory, and other reserved rights, including the copyrights. This message is confidential and may contain legally privileged information. If you are not the intended recipient, you may not use, copy, distribute, deliver or forward this message or any attached documents to any individual or entitiy. In such case, destroy this message and, please notify us so that we can avoid repeating the error. Thank you.
Previous request …
Also requested often is Ordinate Dimensioning …
And from 4.5 years ago …
