I got some good advice from Box on how to create 3D bevels using the Move tool, BUT I’m stuck just getting my geometry to behave…
I imported these 2D vectors from Vcarve, then used Eneroth Face creating to get me this far.
Any advice how I can get the line segments to join (so that I can bevel them into a 3D form)?
ALSO, the faceting that’s being introduced is going to be a problem, since these are going to be CNCed…
Weld them. If you are still using 2018 as your profile indicates, get the Weld plugin from the Extension Warehouse or TIG-Weld from Sketchucation. SketchUp 2021 has a Weld tool as a native feature.
If the forms are circular arcs you could use the Arc tool to redraw them. As SketchUp doesn’t support noncircular curves, welding results only in a faceted polyline. Circles and arcs can be exported to DWG/DXF from the Export>3DModel function that preserves their “arcness”.
I needed true arcs and minimal faceting (as well as to match the designer’s original ACAD elevation)
Sizes are taken straight from designers ACAD…
I’m importing to SU to create a CNCable model…
CNC uses paths, you’d be better off drawing it in something either designed for cnc work or in something like inkscape where you can create beautiful Paths.
And using Dave’s model you can see that the ‘move’ method I showed you earlier means the arcs are retained. This allows you to export them as true arcs.
