Batch Render Plugin
Hello There,
I want to know is there any plugin of batch render for rendering few selected scene from the large list of scenes?
Thank you very much.
If you search on Google after “SketchUp batch render” you will probably find a lot more plugins/software that do what you want.
Here’s a few:
Not sure if its helpful to you but Keyshot has batch rendering and it can also open SketchUp files nativley (including the saved camera settings).
If what you want is simple SketchUp views, place the scenes on pages of a LayOut document and export or print that in one go.
This extension exports all or some scenes in a batch as images with some useful options. Not a renderer, just a fast way to extract all scenes.
https://extensions.sketchup.com/nl/content/s4u-export-scenes
The same can be accomplished by exporting animation as jpg image set without transitions and frame rate set to 1.
Im sorry, I think I did not explain my question, infect I use Vray rendering engine, there is an option for batch rendering. by using that batch rendering option I would like to render few selected scene of my project, for example i have 8 scene of my project. but I do not want to render all those 8 scenes, I would like to render 5 scene out of 8.
Thanks.
Thanks.
Have you looked at this link?
It is very simple and clearly explained how you select only the scenes you want to render.
Just to confirm what the other’s have suggested…In SketchUp…make sure to turn off ‘scene transitions’ and ‘slide delay’.
In VRAY, select ‘Animation’ and ‘Entire Animation’ making sure to set a file path to save images to. As @mihai.s noted, you can choose which scenes to render or not by checking ‘Include in animation’ in SketchUp.
Below, I made 4 scenes. Two were set to be included and two were not. And there you go…only two rendered.
Thankx alot…!
Thank you very much…
