Hello, I have a new Mac and moved the Sketchup Application over. I got an updated serial number but need an Authorization Code to open the application. Help please.
You will want to use the license wizard.
You will be able to email yourself the full license information.
CD
I’ve done that, I still need the Authorization Code…
Pedal & Paddle
Thanks, did that, it changed it and now it is not recognizing it… calling tech support
What version of SketchUp are you installing? The serial numbers and authorisation codes are version specific:
2018 starts with a ’T’
2019 starts with a ‘U’
Hello. I’m using sketchup 2022 trial version. “make face” plugin requires an authorization code. I cannot use the plugin. What can I do for it?
You would need to purchase the extension.
Thank you for the answer
There is face creator, that may do what you need, and is free:
https://extensions.sketchup.com/extension/0fe232b8-f236-4f0c-99a8-b239d9bb5f48/eneroth-face-creator
If you do buy s4u Make Face, make sure to buy it with the email address that you would use if you do get a SketchUp Pro subscription.
FWIW, I would only start using extensions after deciding to use (and buying) SketchUp.
Get to know a bit more of the software and then choose what extensions may or may not work for you.
