Hi, I’m trying to make a hollow box with the front face half the size of the back face, if I grab the lines of the front face with the move tool, and move them down, lines appear ruining the shape on the side faces, is there a way to do this cleanly
If the faces are angled on top, just slice through.
Another option is to put in the edges so it knows where to fold and use the up arrow to constrain to blue.
Edit: The forum software has done it again, if you click the small edit mark you can see the original working gift.
Thank you so much Box, I actually tried that, but I used the eraser so it didn’t worked, I didn’t know about intersect faces with selection, what does that do, does it cut the intersected faces?
Intersect faces will create an edge wherever two faces cross.
