Is it possible to crease multiple edges at once with Artisan Organic Toolset? I want to crease the border of the inner surfaces, but I’m stuck here creasing each individual edge. There’re 176 edges around the 6 curved surfaces…
Edit: I did it manually, but a way to crease multiple edges would still help in the future.
Sorry, haven’t used Artisan for ages, just checked and it doesn’t work like I thought.
SUbD you can preselect the edges before creasing.
But you can drag the crease tool to select a path, shift will deselect any that you select accidentally.
I meant to say ‘subd, for example, lets you preselect’ which is what I expected with Artisan but then checked and found it didn’t.
Wasn’t trying to push you to use SUbD.
