The FACEAREA Attributes seems to fall very short - is there (or best) way to pull an area (Face Area or Volume) into an AutoText in Layout?
Yes.Set the Area units as desired in SketchUp and the area units will carry over in the label auto text
Perfect! Thankyou.
Mike
This AutoText cannot be combined with other Attributes from Dynamic Components. Itâs one of the other.
Ah⌠You didnât specify that in your initial post.
Sorry - you can display multiple Attributes, but thereâs not a âareaâ Attribute you can use along with the others. This is why the Attribute âFACEAREAâ falls short.
Yes, that is a workaround, but it is a bit off a hassle, though.
Even if you set up some combined labels in a scrapbook, make a group of them and then insert it, it wonât pick up the reference to the Component ID.
The only quick way to set it up is to have the different attributes concatenated in a Dynamic Component, and refer to that with the autotext â<DynamicComponent(mylabel)> â
Edit: it wonât parse html tags like </p>, so you would have to convert the autotext to normal textâŚ
I suggest to only put a sample of the âinvisibleâ leader style in scrapbook, then sample it to format as required after placing the multiple leaders set to each data set
