Arch E (36" x 48") paper size available?
Is the paper size Arch E (36" x 48") available? I can’t find it, or ISO size A0, in the default templates.
If not, is there a work-around or a way to make it available?
It’s not in the default templates but you can select the paper size under Document Setup>Paper and make your own template(s)
No work around needed.
Screenshot - 8_14_2017 , 8_49_59 PM
Open Layout_ In File_ Document Setup i
You can also load a paper template and go to the document Setup click on paper size you want. Then move
the existing graphics around as you like. and or add your own.
