Last time I did a design on the default template of A3 but it is slightly different sized then 11 by 17. The printer only had 11 by 17 so part of title block at the bottom got cut off. Below is a screenshot of what the template looks like in A3, would be much appreciated if anyone can suggest a simple way to have the same template in 11 by 17 when I send my sketch up file to Layout.
Thanks for that. When I was looking into what you said I found that 11 by
17 is also known as Tabloid and there is already a construction style
template in tabloid. Cheers
