Any help making this shape into a solid?
Hi guys, been at this for hours, if there is anyone who would be able to make this shape into a solid, that would be so helpful. Thank you!
case.skp (374.0 KB)
Use Solid Inspector and Solid Inspector 2 to help you identify what needs fixing. There’s a bunch of bad geometry in your model.
Compare yours to this one.
case fixed.skp (314.2 KB)
Are you still using SketchUp 2021?
Thank you so much! Yeah, I noticed I had a lot of issues with the internal faces. Genuinely not sure why, I built it the way I build most of my models. Obviously didn’t like something I did. Thank you though!
I am using Sketchup Pro 2024
It looks like an order of operations thing Intersecting the geometry would help you to get rid of most of it.
Fix your forum profile please.
