Any command exist in Ruby Api to exit or deactivate all plugins and return the original UI of Sketchup? Thank you.
You can invoke
Sketchup.plugins_disabled=true
and the next time you start Sketchup, plugins won’t be loaded. Set it false and restart SketchUp to make them load again. For extensions, you can do
Sketchup.extensions.each {|ext| ext.unchecked}
again, this won’t take effect until you restart SketchUp.
Getting Ruby to “forget” about currently loaded plugins is more complicated.
Disabling Ruby Scripts — SketchUp Help
Alternatively - download and install the SketchUcation Plugin Toolset’s RBZ
It has a Plugins-Manager - you just select all Enabled Plugins, and use the Red-button to Disable them. and restart SketchUp.
Later on you can choose to Enable a few of your Plugins, either permanently [Green] or for that session only [Orange].
Note that the ‘ShippedExtensions’ which come with SketchUp will be auto-copied by SketchUp into your Plugins folder - including su_advancedcameratools, su_dynamiccomponents, su_sandbox and su_webtextures - although you might have selected for some of these Extensions to be ‘disabled’ so they aren’t immediately available to use…
