Another Eneroth Autoweld License issue
@colin When you get a minute, can you fix the the settings for Eneroth Weld license. I installed it in 2024, the message is to go to the warehouse to purchase a license (that I already have ).
Thx
D
I could see what the problem was. Try now.
It’s still looking for a license. :slightly_frowning_face:
Uninstall the extension, then install it again.
Good to go , THANKS :blush:
I am also having the same issue with Eneroth Scene Tag Visibility as I set up SU 2024. I have uninstalled and installed again from the extension warehouse. What should I do?
@colin , can you assist @Maxder with his issue?
I found the account you use for extensions, and fixed a problem there. You would have seen the same thing with 2DXY SlickMoves. I fixed that as well.
All good. Thanks so much Colin, appreciate the fast turnaround.
