Animation problem: SketchUp playing two different versions on one screen!
This is just a conceptual mock-up of an idea I have to finish off a wee presentation. Note: the small screen on the far right totally contradicts what’s happening with the main (moving) images - particularly towards the end of the animation. Is this just another ‘characteristic’ of sketchup, or am I doing something fundamentally wrong? So much for a Brexit-stress wind-down!
ROTTEN TOMATOES FIRST ANIMATION.skp (2.5 MB)
it looks like you haven’t yet grasped the basic concept os SU’s scene animation…
if you ‘move’ a single group/component, it will stay moved in all scenes…
to give the impression of the object moving, you need a copy at each position…
for each copy you need a layer so you can easily hide it…
so,
  • scene1, object1______at position1 one has it’s layer visibility turned on
    scene2, object1-copy_ at position2 one has it’s layer visibility turned off
  • scene1, object1_____at position1 one has it’s layer visibility turned off
    scene2, object1-copy_at position2 one has it’s layer visibility turned on
from your snapshot’s you could re-create the positions, using copies and layer visibility…
or start from scratch in a copy of the skp file, so you can reference the old file…
john
Thanks
Is there any alternative to using layers? I tried with them a few years back, thought I’d sussed it then got into horrendous problems with stuff remaining visible, geometry lines popping up all over the place for no reason and in the end I simply gave up! I plan to cart the finished video over into Windows Movie maker, mainly because the animation needs to run at varying speeds. Could I possibly make my life easier by breaking down the Sketchup material into shorter ‘bits’?
IM
you can use ‘hide’ instead of ‘layer visibility’, but you still need copies and it makes it much more difficult to keep organised and modify later…
the alternative is using Ruby and writing your own code or using an existing animation extension…
most cost money and have steeper learning curves compared to scene animation…
stuff remaining visible is controlled by when you hit the refresh button and the presets of what’s being saved…
john
Thanks. Hopefully, there will never * be* a ‘later’…Emoji
POUNDSTRETCHER BUGLY STILL FIGHTING ■■■■ ANIMATION.skp (1.6 MB)
Hi
I’ve re-configured the idea into simple blocks, just to see if I’ve sussed this thing. As you can see: it now works! The only thing I can’t do is change the block to red and this is where it all goes t*ts up, no matter what I attempt. I re-iterate: the ‘proper’ animation is of a product coming on stage, goofing about, having ‘various items’ thrown at it; blushing, then being ‘hoiked off’ stage right. That’s it! Can anybody tell me how to make the blue block turn red in as simple a fashion as possible so that I can complete my presentation and go off for a nice lie down! Please make instructions as idiot-proof as possible and, I BEG, don’t suggest layers (previous posts refer!!)
You need to use layers to make native animations, so I have nothing to suggest.
POUNDSTRETCHER BUGLY ANOTHER BASH AT RED FACE ANIMATION.skp (2.0 MB)
I finally achieved what I was aiming to do by putting a wee ‘mask’ on the original face, then zooming in so that the effects of perspective camouflaged the small alteration in size.
What I cannot seem to overcome is the drastic reduction in image quality which seems to follow the export of the animation to video/Moviemaker. Is there any way overcoming this?
Put another way: is there any method by which more than one animation can be ‘tagged’ onto the end of another whilst remaining in Sketchup? My presentation will feature over a dozen with a running time in excess of ten minutes.
Is it possible to stop the animation from ‘looping’? The returning of all the bits and pieces to their original positions is an unwanted ‘feature’.
