VRay 5 has changed its API. So this does not work with Animator.
I am in contact with Chaos Group to see what can be done.
Thanks Fredo, I appreciate that.
And thanks for making SketchUp great, your work means a lot me.
For info, as of Animator v2.9a and LibFredo6 11.4a, VRay 5 is supported, in addition to previous versions of VRay.
Good to know, the integration of VRay 5 seems much more stable, thanks to its new, documented API.
Wonderful news - and fast, wow. Thank you Fredo
does it support vray 5.1?
I don’t know I haven’t tested
hi. i have a problem fredo. im using sketchup 2020 pro and vray 5. when i try to make animation video with animator and vray, objects disappear from time to time and reappear. the video is distortion.can you help me?
Hello Fredo, how are you, i hope you’re doing great.
I’m using Vray Next 4.20 on Sketchup 2019 with Animator with Animator v3.6a on a LibFredo6 v12.5a.
I have an issue rendering an animation with your animator plugins (which I believe are the latest versions at the moment) the rendering always stops at 20-30%…ALWAYS. Its been really confusing because it renders a normal box well with Vray but when I want to render my project which is like 6mb in size or less it freezes at that 20% range. Please what could be the issue?
PS I had the same problem on Vray 4.1 also. Looking forward to your reply. Cheers
