Animation Export Not As Per Model
Hi - I have created a model that is using groups in Outliner to manage what is seen and not seen and through the use of section lines have created an animation of a building construction sequence. I have been exporting animation from the model to then put into a presentation - everything is fine till the last export was not as per what has been set-up. If I view the animation in the SketchUp program it is fine. If I export it only 2 of the Outliner groups are every visible till part way through when some more suddenly appear. I have tried everything to re-create the model, the scenes, the groups and yet the animation is till not exporting correctly. I have no idea what to try next? Any ideas or solutions? I currently can see my only option is to play the animation inside SketchUp and screen record but this is the last thing I can see being my only solution. Am hoping there is a reason I am missing so as to resolve.
yes. there was a problem with the video export in sketchup 2024.
you can either switch to the classic engine in the preferences, it’ll work, but no ambiant occlusion, or switch to sketchup 2025
Thanks - I tried this but it is still not exporting as it should. This is not very good to buy a piece of software that doesn’t work?
Did you try SketchUp 2025?
Can you share the model?
Did you restart sketchup after changing graphics?
