I was just playing around with the Direct Sun feature in Analysis hub and it is really cool. I am wondering is there a way to set it up to create map like that but for the outdoor space. I work as a landscape architect, and that would be really helpful when creating planting plans.
You can create “spaces” in your SketchUp models that are recognized and accepted by Analysis Hub. The procedure is straightforward:
Draw a horizontal face to represent the floor or site area. Please note that we currently only support horizontal face geometry.
Convert this face into a group or component, as you prefer.
In the “Entity Info” panel, classify the object as “IfcSpace.” To do this, ensure that either the IFC 2x3 or IFC 4 classification is loaded in SketchUp. You can check this by going to “Window” > “Model Info” > “Classifications.” If these are not listed, click “Import” to load them. Once loaded, you can select “IfcSpace” from the “Type” dropdown in the “Entity Info” panel.
Thanks! That is helpful and good information, however in this case I was looking for a “heat map”, that way is easier to see how much sun area receives on a glance
Once you create your IfcSpace(s) in the model, Analysis Hub will not attempt to identify additional spaces during the preparation process.
The face used to create the IfcSpace will be excluded from the model geometry for analysis. Consequently, it will not be visible in the Analysis Hub model viewer or in daylight analysis; it serves solely as a designated region for placing simulation sensor points.
