I guess I have not formulated my question right. To nest one component inside another isn’t my problem.
My problem is that when I nest one component inside the other, the axis of my component doesn’t automatically align with the axis of the “mother component”. But this is what should happen … or not?
I am not so sure anymore.
I want to nest the screw in component 4 which is then the mother component and I’d expect the axis of the screw to align with the axis of component 4 once I nest it.
So based on the picture, the screw should get rotated 90°.
When I make a component or group and change it’s axes and then copy/cut paste it into another component/group it won’t align with the axis BUT when I drag and drop a component from the component window into another component/group or model it does align with the axis.
When I read your post I thought you missunderstood me and think I just want to drag one component into another. I didn’t give great significance to the fact that you drag a component from the component window. I thought this is just another way to select a component/group.
It’s a very useful thing. If you inadvertently delete a component from the model space you can easily replace it with another instance from the Components window. Right now I’m working on the seat for an Adirondack chair. The seat slat components follow a curve but I need to edit them as if they are laid out flat to angle the ends and add rabbets so they’ll fit in the curved channel. Instead of moving the ones on the curve and laying them out flat, I just dragged out copies of them. Due to their component axis orientation and origin locations, it was a very quick thing to lay them out with the required spacing. When I am finished with the extra set of them, I can just delete them.
I have seen another thread today where you show how to replace components with other components from the component window .
That’s indeed very useful e.g. to replace dozens of “proxy components” for screws with “real screw components” later once it’s determined which screws to actually take.
