I have a model with a similar situation, and I kind of solved this issue but with too many steps and I know there is a better and easier way of doing it.
I need to place the skylight on the roof aligned with the guidelines. How do I do it (the smart way
) See attachment.
Thank you!!!
Chris
Skylight.skp (80.0 KB)
You could make the component a âglue toâ component. Here I have made it Glue to Any and have set the axes appropriately in the top left corner.
Thank you Box. Great idea!!!
I guess I have to explode the original component or group and make a component âglue toâ.
No, edit the the component in the component browser to set the glue to, then right click the original and âChange Axesâ then bring in a new version.
Here you go, like this.
I tried to do it as I said and it didnât work, then I followed your second message, and it works great.
If I make a new component glue to any, I guess it would work too, or do I have to edit it after I made it?
Anyway, Iâll try it.
Thanks a lot Box!!
You shouldnât have to edit afterwards, but you can if for some reason it is wrong.
By the way, as it is a skylight, you may want to set the cutting option as well, so that it cuts a hole in your roof. But for that to work you need to place it on the raw geometry of the face of the roof, not the closed component. And it will only cut through one face, so doesnât work with thickness.
I am trying different options. I make the component âglue to slopeâ, and it works too as it is on a sloped roof, but when I made a component âglue to anyâ, and instead of taking it from the Components tray, I move the made component to place it on the roof, it doesnât work (?).
I love SketchUp and I like to understand it.
A glue to component is Glued to the plane you first place it on, so moving one or copying one can be tricky and not do what you expect. So you should bring a new one in for new planes.
You can do arrays and such but you need to be aware of the gluing, you can also right click and choose unglue if you want to move one somewhere else.
Thank you for your great help Box!!!
Chris
