Advise Please - How to safely upgrade from Sketchup 2018 to current Pro account
How to safely upgrade from Sketchup 2018 to current Go Pro account.
With the cost of an upgraded Sketchup Go Pro account will I be able to continue working on current projects established in Sketchup 2018?
without disturbing the current projects in Sketchup 2018
Thank you for your help.
Clarification: Sketchup 2018 to Sketchup Pro Annual account
Each version installs as a separate instance and will not affect your 2018 install. The price can be either annual or monthly.
thank you. I will purchase the year package and get to work.
Please update and correct your forum profile, too. Put in the SketchUp subscription type and SketchUp version. Update the operating system if you are no longer using Win 10 and put in the graphics card make and model number. “intelcore i7 6700” does not identify a graphics card. It’s a whole lot easier to give you assistance if the information in your profile is current and correct.
If with that you mean you can also work on them in SketchUp 2018 after working on them in SketchUp 2026, the short answer is no. Trimble removed the ability to save as an older version a few years ago.
But there are a few ways around that. There is an extension that can open models made in a newer version:
And an extension that allows you to save as an older version:
Hi Herman,
Thank you for the information. I am aware of those versioning limitations; I simply meant that I plan to begin working in SketchUp 2026 moving forward.
I appreciate the recommendations and will definitely look into the extensions you suggested.
Best regards,
Brad Fenwick
You’re welcome.
You should have no problems then. All versions of SketchUp are backwards compatible.
You can leave SketchUp 2018 installed untill you are comfortable with 2026 and have made sure that all your extensions and workflows are compatible with the new version.
Every major update installs as a separate program and can be used beside each other.
One thing to note, 2026 will/should become the default version, so a double click on a 2018 file will open in 2026. If you want to use 2018 open it first then load the file you want.
nice to hear that move, it should help going from 2018-2026.
New question: I’m considering buying a new laptop today to run Sketchup 2026. This is the model I’m considering. Will it be possible to move or “redownload” Sketchup 2026 to a new more powerful laptop?
I have downloaded my 2026 version to an external drive currently on my existing laptop. I don’t have the experience to know if this is possible. Or is there another way to transfer it to a new laptop?
ps. I am still the only user of my purchase. Thanks again for your help. Brad
ASUS ROG Strix G16 (2025) Gaming Laptop, 16” FHD+ 16:10 165Hz/3ms Display, NVIDIA® GeForce RTX™ 5060 Laptop GPU, Intel® Core™ i7 Processor 14650HX, 16GB DDR5, 1TB Gen 4 SSD, Wi-Fi 7, Windows 11 Home
Yes, just go to your account on the SketchUp website, on your products you should be able to download sketchup for desktop from your new laptop.
Do you mean your documents? Copying the sketchup icon to an external drive won’t install sketchup on your new device, you need to run the installer.
