Advice needed: Plastic hangar
Hello. I need some advice on how you would approach the challenge on making a plastic “tent” hangar in Sketchup 2017.
I have currently made an example which has small “bends” in the surface, but it looks abit off in regards to how the actual object looks like. I was planning on correcting that “flat” effect by adding a creased plastic material, but I have not been able to find anything close to the real object.
This is how it looks now:
This is the project I want to replicate:
So; How would you go about making a sketchup project to look like the above real object?
What is the ultimate purpose for which you want the model to look like reality? For rendering? For 3D printing?
If it’s for rendering, then create the necessary materials in the program you’re rendering in.
If it’s for 3D printing, then you’ll need to add details, meaning a lot more geometry (sculpting or subdivisions).
It is for Microsoft Flightsimulator, as a scenery to be used within the sim.
You create a 3D model as realistic as possible, with all the necessary details and textures, along with a simple model (low poly), on which you bake those details into a texture that you apply to it. You can import that low poly model into the specified software.
Either you create a simple model, on which you apply textures that you take from some pictures of the real construction.
Thank you for the suggestion. I wonder what you mean about “bake the details”. I am not familiar with such a function within Sketchup? And why along with? Why would I need two objects?
In your game you will be able to import a light model (lowpoly), one that appears as realistic as possible, and you achieve this through texture over a simple model.
You do the baking using other software, there are many to choose from (xNormal, Marmoset Toolbag, Maya, Blender, etc…). You can find tutorials on YouTube.
As an idea for baking details from high poly model into a low poly model
ok. So no similar functions within Sketchup then. I will basically have to do what I already have done, and adjust textures accordingly. I don’t use other software for modelling and texturing than Sketchup
