Adirondac Chair Question
How would you get from A to B without manually placing each slat? Consider using extensions.
A:
Adirondak Slat Setup Initial
B:
Adirondak Slat Setup Complete
You could use an extension such as Copy Along Curve to distribute the slats. I would copy the curve out of the leg component to use as the path.
adirondack
Note that with CopyAlongCurve you can also equally distribute the number of copies you need by typing that number followed by c. Let the extension sort out the spacing.
adirondack2
Dave, thanks again for your help. Works like a charm. I was trying to avoid manually rotating and this solved my problem.
Happy it helped Tim.
