Adding new combinations in Model Info --> Units
Most of the time I use the Metric system but sometime I also use Imperial units.
Actually, when i select Fractional for inches, I can get only square inches for areas and cubic inches for volumes that are also in fractional format.
This makes no sense to me since, usually, if not nearly all the time, I use areas in square inches of feet (better) as well as volume in cubic feet.
It is only if I select Decimal that I can use different units for Linear, Surface and Volume.
Is it possible for the developers to rethink this and add a more logical way of unit selection when using Fractional?
Thank you.
+1. In principle I am metric only but it seems odd that the developers have ignored this option.
